Port geometry and assignment for dipole antenna (half wavelength)
I am using V4. I want to know what geometry entity to use for port assignment. In comsol tutorial they used rectangle for v3.5
Here in v4 when I try to assign a port to the same rectangle , it simply unavailable for assignment.
Please help
Irfan
2 Replies Last Post 2010年10月13日 GMT+2 10:19
Posted: 1 decade ago 2010年10月13日 GMT+2 08:06
it would make life easier for us out here, to better udnerstand your case, that you could also provide, not only the version, but the physics and some more info about the model.
For the version and the phyiscs, pls use the new options below this would allow us all to easier sort the threads for quicker search.
I find them usefull, but I notice nobody bothers, sad as it would help us all in 2-3 months when we would like to find back something
Hi it would make life easier for us out here, to better udnerstand your case, that you could also provide, not only the version, but the physics and some more info about the model. For the version and the phyiscs, pls use the new options below this would allow us all to easier sort the threads for quicker search. I find them usefull, but I notice nobody bothers, sad as it would help us all in 2-3 months when we would like to find back something -- Good luck Ivar
Posted: 1 decade ago 2010年10月13日 GMT+2 10:19
Thanks Ivar it is V4 RF module. I want to driven a half wave length dipole antenna. The question is for having lumped port as source, What geometric entity is most suitable. I tried assigning rectangle as it was in V3.5 tutorial, but I wonder in V4 that in the port menu, surfaces are not available for assignment, rather a solid may be used.
Now the solid has multiple faces, so if one face is assigned a port, what is the role of other?
Hope this may clarify something
Thanks Ivar it is V4 RF module. I want to driven a half wave length dipole antenna. The question is for having lumped port as source, What geometric entity is most suitable. I tried assigning rectangle as it was in V3.5 tutorial, but I wonder in V4 that in the port menu, surfaces are not available for assignment, rather a solid may be used. Now the solid has multiple faces, so if one face is assigned a port, what is the role of other? Hope this may clarify something
