2010年11月16日 GMT+1 15:52
I have never tried it, but why not: normally the frequency sweep name is "freq" so why not use it to express a BC and test it out, take a simple case you are sure to understand.
And pls report back, interesting question ;)
Hi I have never tried it, but why not: normally the frequency sweep name is "freq" so why not use it to express a BC and test it out, take a simple case you are sure to understand. And pls report back, interesting question ;) -- Good luck Ivar
2010年11月16日 GMT+1 19:23
No luck with the 'freq' command in the BC, even for a single load and single frequency. I only get results with a load value.
If you manage to get a solution, pls let me know.
Many thanks
Hi, No luck with the 'freq' command in the BC, even for a single load and single frequency. I only get results with a load value. If you manage to get a solution, pls let me know. Many thanks
2011年8月3日 GMT+2 23:18
I am wondering if you got to solve your problem.
I am trying to model a pressurized pipe with a point load that acts as a source of vibration. I am not able to apply the pressure without the solver considering both the pressure and point load to be vibration sources.
Angel Suresh
Hi, I am wondering if you got to solve your problem. I am trying to model a pressurized pipe with a point load that acts as a source of vibration. I am not able to apply the pressure without the solver considering both the pressure and point load to be vibration sources. Thanks, Angel Suresh
