[Comsol 3.5a] Visualize drawing dimensions
Hello to all
Is it possible in Comsol visualize the dimension of my drawing, the dimensions like in a technical drawing(for example edge length)?
Thank you
Luca
3 Replies Last Post 2009年10月24日 GMT+2 18:59
Posted: 1 decade ago 2009年10月23日 GMT+2 23:44
Hi Luca
You cannot really visualise the lengths as in a cad tool, but you have the grid frame for the overall dimensions, and you can measure the distance between points and the length of edges with the "ruler" icons in the vertical colum rather to the lower bottom) of icons to the left of your graphics window. This workson raw geometries and "analysed" geometries. the measured length is diplayed in the message window.
Finally you can measure lengths, areas, volumes, inertia etc by first getting the "SOLVE Get Initial Conditions" executed and then do a posprocessing on the edges (integrate 1) surfaces, columes etc or applying more complex functions, rms of the deformed surface ..
Hi Luca You cannot really visualise the lengths as in a cad tool, but you have the grid frame for the overall dimensions, and you can measure the distance between points and the length of edges with the "ruler" icons in the vertical colum rather to the lower bottom) of icons to the left of your graphics window. This workson raw geometries and "analysed" geometries. the measured length is diplayed in the message window. Finally you can measure lengths, areas, volumes, inertia etc by first getting the "SOLVE Get Initial Conditions" executed and then do a posprocessing on the edges (integrate 1) surfaces, columes etc or applying more complex functions, rms of the deformed surface .. Good luck Ivar
Posted: 1 decade ago 2009年10月24日 GMT+2 18:02
Hello Ivar
thanks for your advice, i already know these function, but i thought about visualization like in cad tool, because i am riting a report and i need to display images with coloured subdomains and edge dimensions, in the next days i will try import my geometries in CATIA or Solid edge and I will look for this function in these programs. Have you ever had these problems with Comsol? how did you solve them?
Thank you very much
Luca
Hello Ivar thanks for your advice, i already know these function, but i thought about visualization like in cad tool, because i am riting a report and i need to display images with coloured subdomains and edge dimensions, in the next days i will try import my geometries in CATIA or Solid edge and I will look for this function in these programs. Have you ever had these problems with Comsol? how did you solve them? Thank you very much Luca
Posted: 1 decade ago 2009年10月24日 GMT+2 18:59
it happens that my favorite CAD rool is called SolidWorks, so I do 90% of the cad within this software and link to comsol mostly via parasoilid .x_t file, sometimes using the direct "live" link
For the colors, I even make "fake" groups just to add colors but motly the specific BC's are colored differently by default and I use this for my documentation, eiter by saving the images as jpg or by using snip-it (If on VISTA), and an equivalent cut*paste on UX.
It looks even easier in V4 beta, hope this holds until the formal release ;)
Hi it happens that my favorite CAD rool is called SolidWorks, so I do 90% of the cad within this software and link to comsol mostly via parasoilid .x_t file, sometimes using the direct "live" link For the colors, I even make "fake" groups just to add colors but motly the specific BC's are colored differently by default and I use this for my documentation, eiter by saving the images as jpg or by using snip-it (If on VISTA), and an equivalent cut*paste on UX. It looks even easier in V4 beta, hope this holds until the formal release ;) Good luck Ivar
