2 decades ago
2009年10月30日 GMT+1 07:55
Indeed it sounds strange, these type of questions are typically what I submit to Comsol support.
In the mean time to get around, if you are in 2D and have tubes inside tubes as geometry, probably your view factor is close to 1 so you can anyhow simplify the isue and use a heat exchange just sigma*(T1^4-T2^4) over the boundaries. Anyhow in air radiative heat exchange is rather "soft" and often small compared to conduction or even convection, except if you are cooking or really melting your cable.
2 decades ago
2009年10月30日 GMT+1 18:45
Thank you very much for your suggestions. I´ll try to do it, but I have to read more about Comsol to learn how to do it (I´m just staring using it). Anyway, thank you because now I know I´m not the problem and could be a program bug.
Meanwhile I have also tried using surface to ambient radiation instead of surface to surface radiation, as inner surface of the duct and external surface of the cable are almost concentric and the view factor is near 1. Doing this I have no problems, but I am not sure this is correct, so I don´t know if results are valid, because temperature field is exactly the same I obtain when considering only conduction. As cable temperature is around 50ºC, I think radiation has no effect as you told me (I am not melting the cable).
Anyhow, if radiation has low effect, next step is modeling natural convection inside the duct. In this moment I´m fighting to it, because it doesn´t converge.
Thank you again for your help.
2 decades ago
2009年11月1日 GMT+1 09:09
well if you start with COMSOL you will have some reading, I had to read the books several times to feel comfortable with them, because there is really a lot of matter, in fact it's "all Physics" rewritten in COMSOl approach, with their conventions, not always 100% in line with my (now older) training habits, but its all crrect so it's just to learn it their way. But you will get there, and then it's really fun.
In any case, I must strongy suggest that you always verify your model calculations: do a simple thermal calculations for the heat exchange by an anlytical formulation, get your area, the two temperatures and then multiply by sigma the Boltzmann constant (with the correct power of T in Kelvin, and it's the difference of the T^4 in absolute temperaature and not the ^4 of the difference !) this you find in most thermal analysis books, do not forget to check your units.
This gives you the amount of heat exchange (if you are in 2D you must consider areas as length per meter "depth").
