Electromagnetic force on iron plate
Hello! I made a simple model with AD/DC Magnetic fields no current module. There is a cylindrical magnet and iron plate in it. Iron plate has relative permibility 4000 mur. I calculate the force with which magnet pull the plate. And I get a good result when there is a distance between magnet and the plate. But when the distance between them is 0 (that means that the magnet is in contact with the plate), I suddenly got wrong number. For example, with distance 0.1 mm I get the force about 30 N, but when the distance is 0 - the force is -5.8. How it can be explained? Thank you!
2 Replies Last Post 2017年3月8日 GMT+1 16:30
Nirmal Paudel Tribhuvan University/Electrical Engineering
Posted: 8 years ago 2017年3月7日 GMT+1 16:42
Hi Andrey,
Please see "Magnetic Force/Torque" topic in this blog post:
www.comsol.com/blogs/modeling-magnetic-bearings-in-comsol-multiphysics/
The force calculation when magnet is touching the iron/permeable material is wrong. You would need to apply a thin layer of Thin Low permeability gap to get correct answer.
Hope this helps.
Best Regards,
Nirmal
Hi Andrey, Please see "Magnetic Force/Torque" topic in this blog post: https://www.comsol.com/blogs/modeling-magnetic-bearings-in-comsol-multiphysics/ The force calculation when magnet is touching the iron/permeable material is wrong. You would need to apply a thin layer of Thin Low permeability gap to get correct answer. Hope this helps. Best Regards, Nirmal
Posted: 8 years ago 2017年3月8日 GMT+1 16:30
Thank you! Now it's clear!
