2011年2月17日 GMT+1 07:18
well I haven't seen that one ;) but if you analyse the sentence you should look at the way you define the stress, could it be that you are entering a complex value when a only real was expected, i.e. you are missing an abs() (+ sign) or a real() or perhaps even an imag() for a variable transfer ?
What are the values of this complex value ? is the complex part negligible ? ...
From thereon you should be able to decide how to continue
2011年6月30日 GMT+2 18:10
I'm having the same problem. I'm using version 3.0a and trying to model the effects of thermal expansion of a wire (elasto-plastic material) inside a ceramic material. I keep getting the following error when its finished:
"Evaluation of post processing expression failed. Complex stress function".
The details on my model follow..
Model:
Axial Symmetry (2D) -> Structural Mechanics Module -> Static Analysis Elasto-Plastic Material model
Constants:
Th=1900+273
Tl=298
Rm=200e-6
Ra=2e-2
ht=1e-2
Em=314.5e9
sy0=414e6
Etm=68.9e9
Scalar Expressions:
currT=Tl+(Th-Tl)*(param*(param<=1)+(2-param)*(param>1))
Draw:
Rectangle 1:
corner at origin; width=Rm, height=ht/2
Rectangle 2:
corner at origin; width=Ra, height=ht/2
Subdomain Settings:
(1 - Inner Material):
elastoplastic material
E=Em
nu=0.380
alpha=5.35e-6
rho=10220
Hardening model: isotropic
yield fn: von Mises
sigma_ys=sy0
E_T_iso=Etm
(2- Main material):
isotropic
E=315e9
nu=.239
alpha=7.8e-6
rho=3690
(1&2):
Load->Include thermal expansion is checked
Tempref=Tl
Temp=currT
Boundary Settings:
(2&5 - 'bottom') Rz=0 (symmetry)
Mesh:
Initialized then refined twice (~8000 elements)
Solve:
Static elastoplastic -> Parametric Nonlinear
param = 0:0.01:2
(ramps temperature from room Temp to 1900°C then back down to room temperature).
Nothing else was changed from the default settings.
Model:
Constants:
Th=1900+273
Tl=298
Rm=200e-6
Ra=2e-2
ht=1e-2
Em=314.5e9
sy0=414e6
Etm=68.9e9
Scalar Expressions:
currT=Tl+(Th-Tl)*(param*(param1))
Draw:
Rectangle 1:
Rectangle 2:
Subdomain Settings:
E=Em
nu=0.380
alpha=5.35e-6
rho=10220
yield fn: von Mises
sigma_ys=sy0
E_T_iso=Etm
(2- Main material):
isotropic
E=315e9
nu=.239
alpha=7.8e-6
rho=3690
(1&2):
Tempref=Tl
Temp=currT
Boundary Settings:
Mesh:
Solve:
param = 0:0.01:2
2011年6月30日 GMT+2 19:30
It's the combination of elasto-plastic material and thermal expansion that seems to be failing.
The following simpler model receives the same "Complex stress function" error
Draw a 1x1 square
subdomain:
Use the default material, select elasto-plastic, keep default elastoplastic settings (isostatic w/ tangent modulus).
check "include thermal expansion."
Tempref=298
Temp=298+1000*param
no boundary conditions imposed
solver: static elastoplastic -> nonlinear parameter
param=0:0.2:1
Draw a 1x1 square
subdomain:
Tempref=298
Temp=298+1000*param
param=0:0.2:1
2011年7月5日 GMT+2 19:59
It's the default von Mises yield function (at least in my case) that is causing the error. Using tresca_axi or s1_axi or real(mises_axi) as the yield function runs through successfully (at least for the simple unrestrained geometry).
mises_axi=sqrt(sx^2+sy^2-sx*sy-sy*sz-sx*sz+3*sxy^2+3*syz^2+3*sxz^2+4*Sys^2*eps)
tresca_axi=max(max(abs(s1-s2),abs(s2-s3)),abs(s1-s3))
Nagi Elabbasi
Facebook Reality Labs
2011年7月6日 GMT+2 16:23
Your equation for mises_axi is missing an sz^2 term. That’s why it get negative values.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
2011年7月6日 GMT+2 16:32
Nagi Elabbasi
Veryst Engineering
I apparently forgot it when typing it up above. The mises_axi is a preset variable (so I didn't actually define it within comsol..I was just manually copying it into the forum post from a copy from comsol's variable definition dialog box).
[QUOTE]
Nagi Elabbasi
Veryst Engineering
[/QUOTE]
