Element size
I have a 3D heat conduction model that I would like to know the size of the smallest element in order to compute the Fourier number. In mesh statistics, I see mesh quality which is related to the element aspect ratio and gives me a general idea of the mesh quality. Where can I find the dimensions of the smallest element?
Mike
2 Replies Last Post 2009年11月4日 GMT+1 10:03
Posted: 1 decade ago 2009年11月4日 GMT+1 07:52
I would have a look at the mlinterface.pdf, command.pdf and guide.pdf documents
Sorry I cannt remember just now the variable name, but it's in there somewhere ;)
Hi I would have a look at the mlinterface.pdf, command.pdf and guide.pdf documents Sorry I cannt remember just now the variable name, but it's in there somewhere ;) Good luck Ivar
Posted: 1 decade ago 2009年11月4日 GMT+1 10:03
Hi Mike,
You can do a subdomain or min/max plot and set "h" as the expression to plot. h is Comsol's element size parameter and is calculated as the longest side of each element.
cheers
Amr
Hi Mike, You can do a subdomain or min/max plot and set "h" as the expression to plot. h is Comsol's element size parameter and is calculated as the longest side of each element. cheers Amr
