2009年11月11日 GMT+1 23:12
Hey,
I took a look at your model. There are 2 problems:
1. For the y direction forces in plane-strain boundary conditions, you mistyped and put "Fex_nTy_emes", when it should be "Fes_nTy_emes"
2. You need to check the box that says "Edge load is defined as Force/Area using thickness." The Maxwell Stress tensor generates the force in these units.
After these two changes your model should work.
By the way, you seem to have some unnecessary B.C.s in you model. For example you are applying forces to boundaries which you have already defined as fixed. It might help speed up your model to get rid of any of these unnecessary items.
Good Luck,
Mike
Hey, I took a look at your model. There are 2 problems: 1. For the y direction forces in plane-strain boundary conditions, you mistyped and put "Fex_nTy_emes", when it should be "Fes_nTy_emes" 2. You need to check the box that says "Edge load is defined as Force/Area using thickness." The Maxwell Stress tensor generates the force in these units. After these two changes your model should work. By the way, you seem to have some unnecessary B.C.s in you model. For example you are applying forces to boundaries which you have already defined as fixed. It might help speed up your model to get rid of any of these unnecessary items. Good Luck, Mike
2009年11月12日 GMT+1 00:53
Thank you. But now when i try to simulate it, the solution is not converging. I can see the following error.
Progress - Open Model: Wed Nov 11 18:36:52 EST 2009
Progress - Solve Problem: Wed Nov 11 18:37:38 EST 2009
fem.sol=femstatic(fem, ...
'solcomp',{'lm4','lm3','v','u','V','y','x'}, ...
'outcomp',{'lm4','lm3','v','u','V','y','x'});
Number of degrees of freedom solved for: 136967
Unsymmetric matrix found.
Iter ErrEst Damping Stepsize #Res #Jac #Sol
1 1.1e+025 1.0000000 0.5 2 1 2
2 4.4 0.1000000 4.8 3 2 4
3 1.1 0.4315669 0.94 4 3 6
4 7.2 0.0136752 7.3 6 4 9
Error:
Failed to find a solution:
No convergence, even when using the minimum damping factor.
Returned solution has not converged.
Progress - Solve Problem: Wed Nov 11 18:46:50 EST 2009
'init',init, ...
1 2.8e+025 1.0000000 0.54 2 1 2
3 1.1 0.4315627 0.94 4 3 6
4 7.2 0.0136771 7.3 6 4 9
Error:
I do not know the reason for this.
Thank you. But now when i try to simulate it, the solution is not converging. I can see the following error. ================================================================================ Progress - Open Model: Wed Nov 11 18:36:52 EST 2009 ================================================================================ ================================================================================ Progress - Solve Problem: Wed Nov 11 18:37:38 EST 2009 ================================================================================ fem.sol=femstatic(fem, ... 'solcomp',{'lm4','lm3','v','u','V','y','x'}, ... 'outcomp',{'lm4','lm3','v','u','V','y','x'}); -------------------------------------------------------------------------------- Number of degrees of freedom solved for: 136967 Unsymmetric matrix found. Iter ErrEst Damping Stepsize #Res #Jac #Sol 1 1.1e+025 1.0000000 0.5 2 1 2 2 4.4 0.1000000 4.8 3 2 4 3 1.1 0.4315669 0.94 4 3 6 4 7.2 0.0136752 7.3 6 4 9 Error: Failed to find a solution: No convergence, even when using the minimum damping factor. Returned solution has not converged. ================================================================================ Progress - Solve Problem: Wed Nov 11 18:46:50 EST 2009 ================================================================================ fem.sol=femstatic(fem, ... 'init',init, ... 'solcomp',{'lm4','lm3','v','u','V','y','x'}, ... 'outcomp',{'lm4','lm3','v','u','V','y','x'}); -------------------------------------------------------------------------------- Number of degrees of freedom solved for: 136967 Unsymmetric matrix found. Iter ErrEst Damping Stepsize #Res #Jac #Sol 1 2.8e+025 1.0000000 0.54 2 1 2 2 4.4 0.1000000 4.8 3 2 4 3 1.1 0.4315627 0.94 4 3 6 4 7.2 0.0136771 7.3 6 4 9 Error: Failed to find a solution: No convergence, even when using the minimum damping factor. Returned solution has not converged. I do not know the reason for this.
2009年11月14日 GMT+1 12:13
For me in addition to the comments aready given (I would also remove unnecesary boundaries and items) you have also to define the region for which the [ale] is active (air and not in the structure), as well as the [emes] same as the [ale]
Check carefully all BC to avoid double definitions, and do not foget to switch from physics to physcs (application mode) before setting sub-domain and boundary settings otherwisae you mix up things
Hope this helps, you have a nice model
Hi For me in addition to the comments aready given (I would also remove unnecesary boundaries and items) you have also to define the region for which the [ale] is active (air and not in the structure), as well as the [emes] same as the [ale] Check carefully all BC to avoid double definitions, and do not foget to switch from physics to physcs (application mode) before setting sub-domain and boundary settings otherwisae you mix up things Hope this helps, you have a nice model Good luck Ivar
