How to assign a unit to a variable?
Hey people
I am using 4.0, and I define a long list of variables, so I gave a name, an expression and a description for each of them, but I couldnt assign any unit (the 'unit' column is greyed out), consequently, I noticed 'unexpected unit of input' warning messages under physics I have added so far. Any ideas that I can, somehow, give unit to each variable?
Appreciate much for your help!!
regards
2 Replies Last Post 2016年9月18日 GMT+2 11:58
Posted: 1 decade ago 2011年4月16日 GMT+2 06:56
v4.0 was the first version after the (r)evolution of COMSOL to its new screen and physics approach. Everything was not implemented, I strongly advise you to upgrade to latest version, it contains many enhancements
second a variable normally inherits it's units from the equation you use so if you write v = 4[m]/(2[s]) you should get v=2 and units [m/s] just as for "parameters" apart that normally there is few constant and many other variable names in COMSOL's variales so it does not show th result, as this might be a field, or many values, but then the units do sho up
Hi v4.0 was the first version after the (r)evolution of COMSOL to its new screen and physics approach. Everything was not implemented, I strongly advise you to upgrade to latest version, it contains many enhancements second a variable normally inherits it's units from the equation you use so if you write v = 4[m]/(2[s]) you should get v=2 and units [m/s] just as for "parameters" apart that normally there is few constant and many other variable names in COMSOL's variales so it does not show th result, as this might be a field, or many values, but then the units do sho up -- Good luck Ivar
Posted: 9 years ago 2016年9月18日 GMT+2 11:58
using the version 5.2, in the variable expression i try to use sinh(phi) or cosh(phi) and give them a name , the unit of (phi) is the volt wich is the variable of electrostatic module, but the color is orange and show ''unexpected unit of input'' so i can't used it in boundary condition ad i can't solve my problem
Hi using the version 5.2, in the variable expression i try to use sinh(phi) or cosh(phi) and give them a name , the unit of (phi) is the volt wich is the variable of electrostatic module, but the color is orange and show ''unexpected unit of input'' so i can't used it in boundary condition ad i can't solve my problem Appreciate much for your help!!
