2009年11月23日 GMT+1 22:32
I do not have a ready answer, but I suspect that you can follow some of the suggestions discussed in the Multiphysics Blog some months ago by Niklas ROM of COMSOL,
try out "BACKWARD"
www.comsol.com/community/blogs/multiphysics/9/
Hi I do not have a ready answer, but I suspect that you can follow some of the suggestions discussed in the Multiphysics Blog some months ago by Niklas ROM of COMSOL, try out "BACKWARD" http://www.comsol.com/community/blogs/multiphysics/9/ Good luck Ivar
2009年11月24日 GMT+1 15:44
hi, Ivar,
thanks very much for your reply, it do give me some idea about the inverse problem.i would work on that recently.
en....i still have another problem that is can comsol draw an complex geometry automaticly?
For example, my geometry is a rough surface and i divided into 512 pitchs. In comsol model that means consist of 512 groups rectangular, each rectangular has their own distance. How can i draw the geometry like that?
I do not want to draw 512 times ........
Many many thanks!
hi, Ivar, thanks very much for your reply, it do give me some idea about the inverse problem.i would work on that recently. en....i still have another problem that is can comsol draw an complex geometry automaticly? For example, my geometry is a rough surface and i divided into 512 pitchs. In comsol model that means consist of 512 groups rectangular, each rectangular has their own distance. How can i draw the geometry like that? I do not want to draw 512 times ........ Many many thanks!
2009年11月27日 GMT+1 21:46
well either you could try a periodic boundar condition, or I would first try to make 1-2 elements with COMSOL, then save the file, open the "history" file and analyse the geometry section to complete that with a for loop, but it is probably easier to use matlab as interface, or design it with a CAD tool
Hi well either you could try a periodic boundar condition, or I would first try to make 1-2 elements with COMSOL, then save the file, open the "history" file and analyse the geometry section to complete that with a for loop, but it is probably easier to use matlab as interface, or design it with a CAD tool Good luck Ivar
2009年12月1日 GMT+1 22:55
yeah, thanks Ivar, I thinks matlab would works better.
