PROBLEM: Exporting COMSOL model to Simulink
Posted 2009年12月13日 GMT+1 20:200 Replies
Hi there, I'm trying to export a Navier-Stokes based model (a convective flow around an simple object.....a very simple model).
I'm using the General Dinamic Simulink blocktype for exporting, but when I try to load and run the FEM structure in Simulink-Matlab the following error occurs:
__________________________________________________________________________________________
Error in COMSOL Multiphysics Subsystem block:
Java exception occurred:
Exception:
com.femlab.jni.FlNativeException: Failed to evaluate expression
- Expression: diff(diff(((+(-2*eta_chns*ux+p)*test(ux)+(-eta_chns*(uy+vx))*test(uy)+(-rho_chns*(u*ux+v*uy))*test(u)+(-test(nojac(rho_chns)*(nojac(u)*ux+nojac(v)*uy)+px-nojac(eta_chns)*(2*uxx+uyy+vxy))*taum_chns*res_u_chns))-(+(+(rho_chns)*ut)*test(u)))*(dvol),{test@3}),u)
Failed to evaluate variable
- Variable: taum_chns
- Defined as: nojac(min((timestep/rho_chns),((0.5*h)/max((U_chns*rho_chns),((6*eta_chns)/h)))))
- Expression: nojac(min((timestep/rho_chns),((0.5*h)/max((U_chns*rho_chns),((6*eta_chns)/h)))))
- Variable: timestep
- Geometry: 1
- Dimension: 2
- Domain group: {1}
Stack trace:
at evaltree.cpp, row 757, ()
at evalnodes.cpp, row 754, ()
at xevalutil.cpp, row 2485, ()
at xevalutil.cpp, row 2440, ()
at com.femlab.solver.Linearization.initialize(Native Method)
at com.femlab.solver.Linearization.initialize(Unknown Source)
I have not had any problem by exporting Conduction Heat trasfer models (because their are almost linear..),... but when I try to export a nonlinear model (a fluid dynamics model for example), I always encounter this problem...Is it imposible to export nonlinear fluid dynamics models, even if I use the General dynamic exporting option?
Thanks a lot!!
Exception:
- Geometry: 1
- Dimension: 2
- Domain group: {1}
Stack trace:
Thanks a lot!!
Last Post 2009年12月13日 GMT+1 20:20
Hello Edwin Insuasty
