2010年1月13日 GMT+1 20:45
You have the history file, if its not there by default, should be, you can activate it in the preference settings
Hi You have the history file, if its not there by default, should be, you can activate it in the preference settings Good luck Ivar
2010年1月13日 GMT+1 22:24
Dear Ivar,
Thank you for your response but I think that option just logs the solver scripts. I want to know if I can learn the commands for meshing modelling ; boundary cond. subdomain settings, etc. while doing them from GUI. Is it possible ?
Dear Ivar, Thank you for your response but I think that option just logs the solver scripts. I want to know if I can learn the commands for meshing modelling ; boundary cond. subdomain settings, etc. while doing them from GUI. Is it possible ? Regards,
2010年1月14日 GMT+1 05:28
well the sequence of meshing and group selection etc, is not stored and is rather combersome, as the item index you need to use to identify your boundaries etc are really only identifiable via some graphics interface.
You will have to wait for the (long time expecting by now) V4 to store your meshing sequences, but I'm not sure you will have access to all that way.
but normally you have most of the methodology in the history file, at least I learnt most of ymscripting tricks via de history file, but I agree it took me some time. Furthermore I had to reread the doc half a dozen of times, to catch most subtilities (still in that situation, still rereading reguilarly the docs).
Hi well the sequence of meshing and group selection etc, is not stored and is rather combersome, as the item index you need to use to identify your boundaries etc are really only identifiable via some graphics interface. You will have to wait for the (long time expecting by now) V4 to store your meshing sequences, but I'm not sure you will have access to all that way. but normally you have most of the methodology in the history file, at least I learnt most of ymscripting tricks via de history file, but I agree it took me some time. Furthermore I had to reread the doc half a dozen of times, to catch most subtilities (still in that situation, still rereading reguilarly the docs). Good luck Ivar
