Combine two objects in one, version 4.2.a
Hello Fellows,
I need little help in version 4.2a.
If I for example have one sphere and one conus (there is some intersection between them of course) , how to made one object of these two objects? I want to make just one domain of these two domains.
I tried with union, but I can't solve it on that way.
Thank in advanced.
7 Replies Last Post 2012年6月13日 GMT+2 10:46
Posted: 1 decade ago 2012年6月12日 GMT+2 17:34
can you send an example file?
Felipe
can you send an example file? -- Felipe
Posted: 1 decade ago 2012年6月12日 GMT+2 20:35
Thank you for your help.
This is most simple example of that problem (block + sphere).
How of these two objects (domains) I can make one.
Nikola
Hello, Thank you for your help. This is most simple example of that problem (block + sphere). How of these two objects (domains) I can make one. Regards, Nikola
Posted: 1 decade ago 2012年6月13日 GMT+2 01:13
Nikola,
I'm not able to open your file, comsol says the " ... model is damaged or not valid".
Can you tell me your comsol's version? (the first line that appears in the message tab after opening comsol).
cheers,
Felipe
Nikola, I'm not able to open your file, comsol says the " ... model is damaged or not valid". Can you tell me your comsol's version? (the first line that appears in the message tab after opening comsol). cheers, -- Felipe
Posted: 1 decade ago 2012年6月13日 GMT+2 06:47
you need to upload the file again, I suspect the disk on their server to be full ;) We (I? ;) are too verboose here on the Forum
Hi you need to upload the file again, I suspect the disk on their server to be full ;) We (I? ;) are too verboose here on the Forum -- Good luck Ivar
Posted: 1 decade ago 2012年6月13日 GMT+2 09:56
Hello again,
Version of my comsol is 4.2a.
I am sending you again the file.
Conus + sphere I want to put in one object (domain).
With best regards,
Nikola
Hello again, Version of my comsol is 4.2a. I am sending you again the file. Conus + sphere I want to put in one object (domain). With best regards, Nikola
Posted: 1 decade ago 2012年6月13日 GMT+2 10:09
Add a geometry Bolean operation union node, supress the "keep interiour boundaries" tick and off you go, no ?
Hi Add a geometry Bolean operation union node, supress the "keep interiour boundaries" tick and off you go, no ? -- Good luck Ivar
Posted: 1 decade ago 2012年6月13日 GMT+2 10:46
Aaaa,
that is the trick, I should clear "keep interiour boundaries" box.
Thank you very much Mr Kjelberg .
Nikola
Aaaa, that is the trick, I should clear "keep interiour boundaries" box. Thank you very much Mr Kjelberg . Regards, Nikola
