Arc length
Dear all,
I need to access the arc length as a function of time for a given curve in my simulation for post-processing purposes. Does anyone know the variable for that?
Best regards, NP
3 Replies Last Post 2021年10月25日 GMT+2 08:12
Posted: 3 years ago 2021年10月23日 GMT+2 13:36
Perhaps an integration operator on the boundary and a new variable length=intop1(1).
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Posted: 3 years ago 2021年10月23日 GMT+2 15:45
Updated: 3 years ago 2021年10月26日 GMT+2 01:44
Thank you for your reply! It partially solves the problem. In fact, I need to plot a quantity (and get data) along the arc length. Integrating using intop1(1) will return a single value (total length at a given time). COMSOL uses arc length as default for x-y plotting, but I need to access this variable since I have to modify it (getting a non dimensional parameter).
Thank you so much for your contribution!!
>Perhaps an integration operator on the boundary and a new variable length=intop1(1). Thank you for your reply! It partially solves the problem. In fact, I need to plot a quantity (and get data) along the arc length. Integrating using intop1(1) will return a single value (total length at a given time). COMSOL uses arc length as default for x-y plotting, but I need to access this variable since I have to modify it (getting a non dimensional parameter). Thank you so much for your contribution!!
Posted: 3 years ago 2021年10月25日 GMT+2 08:12
For all arc there is an inherent coordinate called 's' which runs from 0 to 1. You can use that to plot as a function of the arc length.
Acculution ApS
www.acculution.com
info@acculution.com
