Magnetic force calculations
Posted 2023年8月2日 GMT+2 10:41 Electromagnetics, Mesh 1 Reply
Hi All,
I hope someone will have insight into the following issue I encountered: I'm modeling a system using the magnetic fields in the AC/DC module and would like to calculate the magnetic force on metal components in a field of an electromagnet.
It seems that the result is very dependent on the mesh definition (varying from 5N to 155N depending on the mesh made) so I was wondering what is the proper way to set up the mesh and check if it is appropriate?
I would appreciate any thoughts on the issue :) thanks!
