Edgar J. Kaiser
Certified Consultant
1 year ago
2023年8月11日 GMT+2 21:34
Hi Chenxi,
I recently encountered similar problems in such a setup. The model was running fine in a rather ugly mesh and showed a similar error in a better and finer mesh. According to COMSOL support a reason may be inappropriate tuning of mesh size and time stepping. The time stepping adjustment is very critical in the time explicit solvers. So time stepping and meshing may be the field to play in.
So far I didn't solve the issue and I am still working with the ugly mesh with locally bad aspect ratio. However this shows different issues at long runtimes.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Chenxi,
Cheers
Edgar
1 year ago
2023年8月11日 GMT+2 23:38
Hi Edgar,
Yes, I also noticed that the model somehow works when I set the time range small, as I increase the time range while keeping the same time stepping, the error starts to show up. I may try to play with the mesh and see how things will work.
Thank you for your reply! I really apreciate it :))
Chenxi
Hi Edgar,
Chenxi
