Vibration Simulation On different frequencies at COMSOL multiphysics
Posted 2023年8月17日 GMT+2 14:52 0 Replies
I want to made a simulation model where I want to measure the pressure on the human skin created by an arrary of twenty-five coin vibrational motors. So every single coin type vibrational motor will create vibration force on the basis of differnt frequencies. I want to simulate for a single motor and later on for the whole arry of vibration motors. The frequency range will be 10Hz to 55 Hz. The diameter of the motor is 12 milimeters and the thickness of outer structure is 3.5 milimeters. The motor is powered with minimum 03 volts. So the input will be vibrational frequncies and output will be generated pressure or force per square milimeters. I need help for simulation model setup perameters idea. Please guide me from your expertise experience such as
i) what type of material I need to use (There is no specification about the material inside the datasheet) ?
ii) What will be best suitable physics I need to attached?
iii) What kind of study I need to choose ?
I have attached the datasheet of the motor with this post.
Thank you.
Hello Md Tanvirul Kabir Chowdhury
