Robert Koslover
Certified Consultant
1 year ago
2023年8月24日 GMT+2 00:48
Updated:
1 year ago
2023年8月24日 GMT+2 00:49
I presume you are talking about electromagnetic fields? You can compute reactive near fields with either the AC/DC module or the RF module, via the directly computed local fields (computed using the finite-element method) within the meshed volume in/around your electromagnetic device of interest. If you want to compute the radiating near-fields, you can either: (1) try to expland your meshed computational volume far enough (sometimes possible), (2) employ Comsol's boundary-element formulation (which also sometimes works well), or (3) implement a near-field version of the Stratton-Chu aperture field integration method via custom post-processing. In regard to the 2nd approach, see https://www.comsol.com/model/fem-bem-coupling-of-a-microstrip-patch-antenna-102981 .
In regard to implementing the 3rd approach, see https://www.comsol.com/community/exchange/672/ .
I presume you are talking about electromagnetic fields? You can compute *reactive* near fields with either the AC/DC module or the RF module, via the directly computed local fields (computed using the finite-element method) within the meshed volume in/around your electromagnetic device of interest. If you want to compute the *radiating* near-fields, you can either: (1) try to expland your meshed computational volume far enough (sometimes possible), (2) employ Comsol's boundary-element formulation (which also sometimes works well), or (3) implement a near-field version of the Stratton-Chu aperture field integration method via custom post-processing. In regard to the 2nd approach, see https://www.comsol.com/model/fem-bem-coupling-of-a-microstrip-patch-antenna-102981 .
1 year ago
2023年8月24日 GMT+2 02:54
Updated:
1 year ago
2023年8月24日 GMT+2 02:55
Yes, my project is about the eletromagnetic fields. Well, I'm going to focus in yours sugestion number 3. But I still some questions to continue my simulation with this method.
1_In the step 3, the surfaces that I select for integrate is the most external, like a limits? I didn't understand well this step.
2_Can I keep the conditions that were created about Perfect Eletric Condutor, Lumped Port, etc?
3_Can I obtain the Magnetic Field if I replace the expression "abs(ApInt(Epx))/sqrt(2)" or this simulation only generate Eletric Field?
Thank you very much!
