rotational constraint
AMAL IIT KANPUR/AEROSPACE ENGINEERING
I am trying to do a static analysis of a cantilever beam whose one end is fixed.
In the other end I am applying forces axially and also in the transverse direction. But I what this end to be rotationally restraint, but can undergo an axial and transverse deflection. The final deformation of the beam will look somewhat like the attached figure.
While I am able to do everything else, i am not able to figure out! how to give a rotational restraint constraint. Someone please help!
2 Replies Last Post 2023年9月25日 GMT+2 11:12
Raja Kumar Acoustics & Vibration
Posted: 11 months ago 2023年9月25日 GMT+2 10:44
There will be options to add contraint type as rotational and translation constraint
iamrajakumar@iitkgp.ac.in
iamrajakr@gmail.com
Posted: 11 months ago 2023年9月25日 GMT+2 11:12
Assuming that you are using Solid Mechanics, there are two direct approaches:
Approach 1:
Add aRigid Connectorto the end boundary and constrain its rotation.
Approach 2:
Add aSymmetrycondition to the end boundary, and make use of the settings in itsNormal Direction Conditionsection.
Henrik Sönnerlind
COMSOL
Assuming that you are using Solid Mechanics, there are two direct approaches: Approach 1: Add a *Rigid Connector* to the end boundary and constrain its rotation. Approach 2: Add a *Symmetry* condition to the end boundary, and make use of the settings in its *Normal Direction Condition* section.
