11 months ago
2023年9月29日 GMT+2 19:07
Updated:
11 months ago
Hello
Are you referring to this example?
https://www.comsol.com/model/surface-acoustic-wave-gas-sensor-2129
It does not use s-parameters so I am curious what you changed or are doing? It uses electrostatics, at least that is what i see in the file. I cannot simulate the file as I don't have the mems module but I can see the setup.
What equation are you using to calculate AC power?
Hello Are you referring to this example? https://www.comsol.com/model/surface-acoustic-wave-gas-sensor-2129 It does not use s-parameters so I am curious what you changed or are doing? It uses electrostatics, at least that is what i see in the file. I cannot simulate the file as I don't have the mems module but I can see the setup. What equation are you using to calculate AC power?
11 months ago
2023年10月7日 GMT+2 03:50
Updated:
11 months ago
2023年10月10日 GMT+2 03:34
Hello
Yes, it is the example. I was following the steps of the veido from the linkhttps://www.youtube.com/watch?v=FqL6NXh6kZY. I plotted the s-parameters by setting a terminal boundary with fixed power in electrostatics and performing frequency domain study.
>Hello > >Are you referring to this example? > >https://www.comsol.com/model/surface-acoustic-wave-gas-sensor-2129 > >It does not use s-parameters so I am curious what you changed or are doing? It uses electrostatics, at least that is what i see in the file. I cannot simulate the file as I don't have the mems module but I can see the setup. > >What equation are you using to calculate AC power? Yes, it is the example. I was following the steps of the veido from the link [https://www.youtube.com/watch?v=FqL6NXh6kZY](https://www.youtube.com/watch?v=FqL6NXh6kZY). I plotted the s-parameters by setting a terminal boundary with fixed power in electrostatics and performing frequency domain study.
