Tapered Waveguide
Anyone can help me? I am following Tapered Waveguide Tutorial. I want to redraw and resimulate the tapered with different size and design. The new design is combining down tapered in start, straight tapered in the middle and up tapered in the last.
What i should change from the tutorial?
Your recommendation is highly appreciated
4 Replies Last Post 2023年10月7日 GMT+2 13:11
Posted: 11 months ago 2023年10月4日 GMT+2 15:15
Updated: 11 months ago 2023年10月4日 GMT+2 15:19
If I understand you correctly, you are asking about how to use the 2D and 3D drawing tools. I encourage you to work through some of the tutorials available in the Applications Library. Also, just experiment with the features provided. The Help system is sometimes actually helpful, too. Operations such asextrude,sweep,revolve, andloftare definitely worthy of some study, in addition to the various Boolean operations, and such simple operations asmove,rotate,scale, and others. Learn how to use Workplanes. Learn about using bezier curves and parametric curves, surfaces, etc. After enough practice and experience, you will be quite skilled in creating very complex and completely custom geometries. See also https://www.comsol.com/support/learning-center .
If I understand you correctly, you are asking about how to use the 2D and 3D drawing tools. I encourage you to work through some of the tutorials available in the Applications Library. Also, just experiment with the features provided. The Help system is sometimes actually helpful, too. Operations such as *extrude*, *sweep*, *revolve*, and *loft* are definitely worthy of some study, in addition to the various Boolean operations, and such simple operations as *move*, *rotate*, *scale*, and others. Learn how to use Workplanes. Learn about using bezier curves and parametric curves, surfaces, etc. After enough practice and experience, you will be quite skilled in creating very complex and completely custom geometries. See also https://www.comsol.com/support/learning-center .
Posted: 11 months ago 2023年10月5日 GMT+2 05:28
Thank you for your reply. I have no problem to draw. I am referring to the tutorial Tapered Waveguide. The tutorial shows down tapered, but my design structure is combining a down tapared(left), straight waveguide (middle) and upper tapered (right). I am doubt that i can use the same step for DEFINITION and STUDY.
2) I also confuse what is the different with d_taper and n_taper as mentioned in parameter file ?
n_taper 200 "Taper length in vacuum wavelengths" d_taper n_taper*lam0 "Taper length"
3) Why use lam0 as 1.55um wavelength? can use UV wavelength?
Thank you in advanced
Thank you for your reply. I have no problem to draw. I am referring to the tutorial Tapered Waveguide. The tutorial shows down tapered, but my design structure is combining a down tapared(left), straight waveguide (middle) and upper tapered (right). I am doubt that i can use the same step for DEFINITION and STUDY. 2) I also confuse what is the different with d_taper and n_taper as mentioned in parameter file ? n_taper 200 "Taper length in vacuum wavelengths" d_taper n_taper*lam0 "Taper length" 3) Why use lam0 as 1.55um wavelength? can use UV wavelength? Thank you in advanced
Posted: 11 months ago 2023年10月6日 GMT+2 15:21
Updated: 11 months ago 2023年10月6日 GMT+2 15:21
Sorry, I thought you were talking about anRFwaveguide model. The model to which you refer is optical. But, more importantly, it also involves some rather careful customizations, so I suggest that other readers -- those more familiar than I am with novel optical fiber structure modeling using Comsol Multiphysics -- respond.
Sorry, I thought you were talking about an *RF* waveguide model. The model to which you refer is optical. But, more importantly, it also involves some rather careful customizations, so I suggest that other readers -- those more familiar than I am with novel optical fiber structure modeling using Comsol Multiphysics -- respond.
Posted: 11 months ago 2023年10月7日 GMT+2 13:11
Anyway, thank you for your concern. I really apprecieated it. Hope for an optical simulator can help me for some solutions ;-)
