Henrik Sönnerlind
COMSOL Employee
11 months ago
2023年10月16日 GMT+2 09:43
TheUser definedoption in theCreepnode allows only isotropic creep. You do however have a possibility to define a general anisotropic creep law by adding anInelastic Strain Ratenode.
If you are working in 3D, select a cylindrical coordinate system. Use the same coordinate system in the parentLinear Elastic Materialnode, so that you have access to the corresponding stress components.
If you are working in a 2D axisymmetric geometry, the cylindrical system is part of the formulation.
Henrik Sönnerlind
COMSOL
The *User defined* option in the *Creep* node allows only isotropic creep. You do however have a possibility to define a general anisotropic creep law by adding an *Inelastic Strain Rate* node. If you are working in 3D, select a cylindrical coordinate system. Use the same coordinate system in the parent *Linear Elastic Material* node, so that you have access to the corresponding stress components. If you are working in a 2D axisymmetric geometry, the cylindrical system is part of the formulation.
10 months ago
2023年10月17日 GMT+2 14:22
Thank you Henrik for your response. Your suggestion will help me a lot. However I am new to use inelastic strain rate node. Can you please give me more explanations on how to use inelastic strain rate node to define this creep law. Thank you very much for suggestions.
Henrik Sönnerlind
COMSOL Employee
10 months ago
2023年10月18日 GMT+2 08:24
The entries are the components of the strain rate tensor. Essentially, you just have to select the format of the tensor (Diagonal or Symmetric) and then use the expressions from your first posting, but substituted with whatever the quantites would be called in your model. The stresses would be something like
sigma_t -> solid.s22 sigma_a -> solid.s33
Note that you need to provide the full tensor (even though you may decide to set some components to zero, assuming that there is no creep in that direction).
An important aspect is whether the physical creep process is volume preserving or not. If it is, the strain rate tensor must be designed to have that property. For example, the radial strain rate (not mentioned by you), cannot be chosen arbitrarily, since in this case it is required that trace(epsilon_dot) = 0.
Henrik Sönnerlind
COMSOL
The entries are the components of the strain rate tensor. Essentially, you just have to select the format of the tensor (Diagonal or Symmetric) and then use the expressions from your first posting, but substituted with whatever the quantites would be called in your model. The stresses would be something like sigma_t -> solid.s22 sigma_a -> solid.s33 Note that you need to provide the full tensor (even though you may decide to set some components to zero, assuming that there is no creep in that direction). An important aspect is whether the physical creep process is volume preserving or not. If it is, the strain rate tensor must be designed to have that property. For example, the radial strain rate (not mentioned by you), cannot be chosen arbitrarily, since in this case it is required that trace(epsilon_dot) = 0.
10 months ago
2023年10月20日 GMT+2 06:56
Thanks, Henric for your response.I will try it.
10 months ago
2023年10月21日 GMT+2 07:05
Hi Henric, First I described the creep rate equation in the variable subnode. Then use it in the inelastic strain rate tensor, But I am facing many convergence errors. Have a look on my model which I attached. Thanks for your suggestions.
