COMSOL Employee
11 months ago
2023年10月17日 GMT+2 15:25
Updated:
11 months ago
2023年10月17日 GMT+2 15:24
Hello Alexey,
It is certainly possible to evaluate the effective properties of an inhomogeneous material using simulation. Seethis tutorialfor an example. If your composite is periodic, you may be able to get away with simulating a single cell, as illustrated inthis second example. If on the other hand you need to generate a large number of nanoparticles randomly distributed in the matrix, seethis blog poston how to do it through a script.
Hello Alexey, It is certainly possible to evaluate the effective properties of an inhomogeneous material using simulation. See [this tutorial](https://www.comsol.com/model/effective-diffusivity-in-porous-materials-978) for an example. If your composite is periodic, you may be able to get away with simulating a single cell, as illustrated in [this second example](https://www.comsol.com/model/equivalent-properties-of-periodic-microstructures-23621). If on the other hand you need to generate a large number of nanoparticles randomly distributed in the matrix, see [this blog post](https://www.comsol.com/blogs/how-to-create-a-randomized-geometry-using-model-methods/) on how to do it through a script. Best, Jeff
10 months ago
2023年10月22日 GMT+2 16:43
Hello Alexey,
I'm grateful for response. I successfully created the geometry of nanocomposite. The only one problem now is how to measure thermal conductivity? Is there some standart algorithm in COMSOL?
>Hello Alexey, > >It is certainly possible to evaluate the effective properties of an inhomogeneous material using simulation. See [this tutorial](https://www.comsol.com/model/effective-diffusivity-in-porous-materials-978) for an example. If your composite is periodic, you may be able to get away with simulating a single cell, as illustrated in [this second example](https://www.comsol.com/model/equivalent-properties-of-periodic-microstructures-23621). If on the other hand you need to generate a large number of nanoparticles randomly distributed in the matrix, see [this blog post](https://www.comsol.com/blogs/how-to-create-a-randomized-geometry-using-model-methods/) on how to do it through a script. > >Best, > >Jeff I'm grateful for response. I successfully created the geometry of nanocomposite. The only one problem now is how to measure thermal conductivity? Is there some standart algorithm in COMSOL?
COMSOL Employee
10 months ago
2023年10月23日 GMT+2 15:39
Updated:
10 months ago
2023年10月23日 GMT+2 15:45
You derive the equivalent conductivity of a sample from the formula q=-k*grad(T) .
You run a simulation with an imposed heat flux through the sample and obtain from that simulation the temperature drop; then using the formula above (and the length of the sample, as you can approximate
) you get k.
You derive the equivalent conductivity of a sample from the formula q=-k*grad(T) . You run a simulation with an imposed heat flux through the sample and obtain from that simulation the temperature drop; then using the formula above (and the length of the sample, as you can approximate grad(T) \approx \Delta T / L ) you get k. Jeff
