Magnetic Field-Solid Mechanics Coupled Problem
I have a 2D model in which I tried to simulate the deflection of the magnetic polymer under constant magnetic field. For this purpose, I used magnetic fields module and solid mechanics module with magnetomechanical multiphysics. I fixed the bottom of my geometry and applied uniform magnetic field. Although, I change the direction of the magnetic field, geometry still deflects at the same direction. Also, I observed when I change some geometrical dimensions, it deflects in an unsymmetric way; although the magnetic field is constant.
If you can help me with these, I will be glad.
Thank you so much for your help.
Kind regards
1 Reply Last Post 2024年2月23日 GMT+1 08:23
Hello Feyza Pirim
Prasanna Kumar Routray
Posted: 6 months ago 2024年2月23日 GMT+1 08:23
Hi Feyza, Were you able to solve this? I'm facing similar issue.
Please provide an example if you were able to solve this.
Thanks.
Hi Feyza, Were you able to solve this? I'm facing similar issue. Please provide an example if you were able to solve this. Thanks.
