Structural Mechanics Error When Making Model Smaller
Posted 2023年10月26日 GMT+2 03:18 Geometry, Structural Mechanics, Physics Interfaces Version 6.1 2 Replies
I am recently starting a project and I wanted to apply the solid mechanic functions with the shell function. I used the block_on_arch file in the COMSOL libraries to understand the functionalities since I am relatively new to structural mechanics.
However, when I attempted to downsize the file from a mm unit to a nm unit, the solver had large errors. I ran the file in mm originally with my desired dimensions and it runs just fine. However, when I change it to nm, it does not produce a result. Is there a measurement in the shell physics, where the error originates from, that I am unaware of? Or is it difficult to apply the same calculations to an extremely small model?
I attached the modified block_on_arch file
Thank you, Zafiro
