Robert Koslover
Certified Consultant
10 months ago
2023年11月7日 GMT+1 23:05
Updated:
10 months ago
2023年11月7日 GMT+1 23:02
There are a lot of possible causes of this. If you've already tried the steps in the article you cited, then I'm guessing you have some kind of error in your setup that you are simply overlooking. Have you been able to get a simpler model that is otherwise similar to work? If you can simplify your model to the point it is non-proprietary (e.g., replace your complicated geometry with just a cube and/or cylinder, for instance, and maybe change your time scale to 0 to 1 second, modify and/or rename all your materials, etc.), andthenif it still exhibits the same issues as before, you could post that model here and just might receive some useful advice.
There are a lot of possible causes of this. If you've already tried the steps in the article you cited, then I'm guessing you have some kind of error in your setup that you are simply overlooking. Have you been able to get a simpler model that is otherwise similar to work? If you can simplify your model to the point it is non-proprietary (e.g., replace your complicated geometry with just a cube and/or cylinder, for instance, and maybe change your time scale to 0 to 1 second, modify and/or rename all your materials, etc.), and *then* if it still exhibits the same issues as before, you could post that model here and just might receive some useful advice.
10 months ago
2023年11月15日 GMT+1 21:48
Updated:
10 months ago
2023年11月15日 GMT+1 23:14
Hi Robert,
Thank you so much for your reply, apologies for not getting back until now.
I have created a simplified version of the model which I can now post. The NL fails have (for the most part) stopped but I have 2 different curious issue.
The solid domains on my part seem to get crazy hot (4830 degC after 20 seconds), even though they are the container of a pipe with constant flow. If the water is entering the pipe at 20 degrees celcius, shouldn't this cool down the solid part?
The fluid appears to be travelling in the opposite direction that I want it to (i.e. out the inlet and in the outlet). At first it was not doing this, but I cannot figure out which condition is affecting it.
I'm a comsol newbie so I am sure these issues are on me and not anything actually wrong. If anyone could please look over my model (especially the BCs), I would be very grateful :)
Thanks so much, Odette
Hi Robert, Thank you so much for your reply, apologies for not getting back until now. I have created a simplified version of the model which I can now post. The NL fails have (for the most part) stopped but I have 2 different curious issue. 1. The solid domains on my part seem to get crazy hot (4830 degC after 20 seconds), even though they are the container of a pipe with constant flow. If the water is entering the pipe at 20 degrees celcius, shouldn't this cool down the solid part? 2. The fluid appears to be travelling in the opposite direction that I want it to (i.e. out the inlet and in the outlet). At first it was not doing this, but I cannot figure out which condition is affecting it. I'm a comsol newbie so I am sure these issues are on me and not anything actually wrong. If anyone could please look over my model (especially the BCs), I would be very grateful :) Thanks so much, Odette
10 months ago
2023年11月16日 GMT+1 17:21
Updated:
10 months ago
2023年11月16日 GMT+1 22:57
Hi again,
I think the issues have to do with my fluid flow boundary conditions. The velocity of the fluid is very low, which explains why the temperature is reaching high values.
I have changed the boundary conditions so that there is a pressure condition (90 psi) on the inlet and a velocity condition (3.157 m/s or 40 L/min) on the outlet. But now I am back to the convergence issues, with NL fails and T fails. Not sure why because the problem seems rather simple (fluid through a pipe with a heat source).
I attached the model with said changes. Please advise, I have researched the issue extensively but no luck.
Thank you, Odette
Hi again, I think the issues have to do with my fluid flow boundary conditions. The velocity of the fluid is very low, which explains why the temperature is reaching high values. I have changed the boundary conditions so that there is a pressure condition (90 psi) on the inlet and a velocity condition (3.157 m/s or 40 L/min) on the outlet. But now I am back to the convergence issues, with NL fails and T fails. Not sure why because the problem seems rather simple (fluid through a pipe with a heat source). I attached the model with said changes. Please advise, I have researched the issue extensively but no luck. Thank you, Odette
