Maximum number of Newton iterations reached
Posted 2023年11月9日 GMT+1 05:30Version 5.61 Reply
Good morning, I work on a simulation of an interaction fluid/structure and I want to apply pneumatic forces on a sheet which is levitated with those forces and try to find the link between the distance between the sheet and the inlet, and the force apply on the sheet. This distance should be between 0.01mm and 5mm However, my simulation failed to find a solution beacause the solution is not converged. So I have the error : Maximum number of Newton iterations reached. I really don't know how to solve this, so if someone have a solution I will be glad.
Thank you very much.
