Error in user-defined function
Time: 1833412.0064212149 s. Error in user-defined function. Function: comp1.mat1.def.k Failed to evaluate variable. Variable: comp1.ht.k effxx, Defined as: (unit W cfcomp1.mat1.def.k(comp1.ht.bm1.minput relativehumidity))/(unit m cfunit K cf) Failed to evaluate variable. Variable: comp1.ht.dfluxx, Defined as: ((comp1.Tx(-comp1.ht.k effxx))-((d(unit Pa cfcomp1.ht.bm1.fpsat(comp1.T/unit K cf),comp1.T)((comp1.ht.Lvcomp1.ht.delta p)comp1.ht.phi))comp1.Tx))-(d(comp1.ht.phi,x)(unit Pa cf((comp1.ht.Lvcomp1.ht.delta p)comp1.ht.bm1.fpsat(comp1.T/unit K cf)))) Failed to evaluate expression. Expression: dvol spatial(comp1.ht.dcomp1.ht.dfluxx) Failed to evaluate Jacobian of expression. Expression: (comp1.ht.dfluxxtest(comp1.Tx)comp1.ht.d)(dvol spatial) Error in user-defined function. Function: comp1.mat1.def.k Failed to evaluate variable. Variable: comp1.ht.k effxx, Defined as: (unit W cfcomp1.mat1.def.k(comp1.ht.bm1.minput relativehumidity))/(unit m cfunit K cf) Failed to evaluate variable. Variable: comp1.ht.dfluxx, Defined as: ((comp1.Tx(-comp1.ht.k effxx))-((d(unit Pa cfcomp1.ht.bm1.fpsat(comp1.T/unit K cf),comp1.T)((comp1.ht.Lvcomp1.ht.delta p)comp1.ht.phi))comp1.Tx))-(d(comp1.ht.phi,x)(unit Pa cf((comp1.ht.Lvcomp1.ht.delta p)*comp1.ht.bm1.fpsat(comp1.T/unit K cf)))) Failed to evaluate expression.
1 Reply Last Post 2023年11月27日 GMT+1 20:24
Posted: 9 months ago 2023年11月27日 GMT+1 20:24
Updated: 9 months ago 2023年11月27日 GMT+1 20:15
Without context, you are unlikely to receive feedback beyond what you've probably already understood, namely that at the time indicated the software is unable to evaluate the function comp1.mat1.def.k for some reason. Consider attaching your mph file and a description of what you are trying to model.
Hello, Without context, you are unlikely to receive feedback beyond what you've probably already understood, namely that at the time indicated the software is unable to evaluate the function comp1.mat1.def.k for some reason. Consider attaching your mph file and a description of what you are trying to model. Best, Jeff
