Application of AC current injection through surface electrodes in frequency domain analysis in skin
Tananant Boonya-ananta
Hello, I have been looking for a method to inject AC current through skin surface electrodes and perform frequency domain analysis at each time point (represented by a parametric sweep across various geometrical changes). This is low amperage and betwen 10KHz to 100KHz.
I am unsure how to perform this analysis or go about specifying the AC current source frequency since I am analyzing in the frequency domain, not in time. Ideally, I would like to sweep across multiple frequencies to test electrode performance.
Thank you.
4 Replies Last Post 2024年2月15日 GMT+1 19:28
Posted: 7 months ago 2024年2月7日 GMT+1 19:44
Updated: 7 months ago 2024年2月7日 GMT+1 19:44
  1. You can do afrequency sweepin frequency domain. If timetruly doesn't matterfrom the perspective of the physics, then you don't have to care about it. If you wish, you can (mentally, or with a pencil and paper) associate each frequency with whatever time you wish (e.g., "If this is Belgium, it must be Thursday.") Now, if thephysicsinvolvedactually depend on time, then you should use a time-domain model. But I doubt that is the case here.
  2. Based on your description, I suspect you will be (or should be) using the Electric Currents (EC) interface, which is part of the AC/DC module. That's where I would start, anyway. That should support your frequency domain model. You'll need to specify the conductivity of the skin/flesh, of course. I hope that helps.
1. You can do a *frequency sweep* in frequency domain. If time *truly doesn't matter* from the perspective of the physics, then you don't have to care about it. If you wish, you can (mentally, or with a pencil and paper) associate each frequency with whatever time you wish (e.g., "If this is Belgium, it must be Thursday.") Now, if the *physics* involved *actually depend on time*, then you should use a time-domain model. But I doubt that is the case here. 2. Based on your description, I suspect you will be (or should be) using the Electric Currents (EC) interface, which is part of the AC/DC module. That's where I would start, anyway. That should support your frequency domain model. You'll need to specify the conductivity of the skin/flesh, of course. I hope that helps.
Posted: 7 months ago 2024年2月15日 GMT+1 17:07
Updated: 7 months ago 2024年2月15日 GMT+1 17:04
Hello Robert,
Thank you for your reply. Your advice is very helpful. I am using the EC interface model from the AC/DC module. The main concern that I had is, how do I define my input current as an AC signal. I use a simple "Terminal" definition for the injection current at 0.4mA and a "Ground". This is where I'm curious as to how to define a driving frequency of 10kHz for the AC current at Terminal 1? Is this accomplished through simply defining the freq in frequency domain study? To respond to point 1: to the best of my knowledge (I may be complete wrong), but in this case I simulate "time" by doing a parametric sweep of the geometrical changes with time that has been calculated previously. Since the physical changes are expected to be significantly slower than AC freq, this should be ok.
Thank you very much, I greatly appreciate your kind assistance.
Hello Robert, Thank you for your reply. Your advice is very helpful. I am using the EC interface model from the AC/DC module. The main concern that I had is, how do I define my input current as an AC signal. I use a simple "Terminal" definition for the injection current at 0.4mA and a "Ground". This is where I'm curious as to how to define a driving frequency of 10kHz for the AC current at Terminal 1? Is this accomplished through simply defining the freq in frequency domain study? To respond to point 1: to the best of my knowledge (I may be complete wrong), but in this case I simulate "time" by doing a parametric sweep of the geometrical changes with time that has been calculated previously. Since the physical changes are expected to be significantly slower than AC freq, this should be ok. Thank you very much, I greatly appreciate your kind assistance.
Posted: 7 months ago 2024年2月15日 GMT+1 17:18
Updated: 7 months ago 2024年2月15日 GMT+1 17:21
Defining the frequency in the frequency domain study does indeed define the frequency. If/when you specify 0.4mA for the input current, that will then set theamplitudeof the impliedsinusoidalcurrent (at the subject frequency) to 0.4mA. I'm not entirely sure what you are doing in detail in regard to this or your other boundary conditions, but I think (tentatively) that you are on the right track. You might also want to check if there are some similar (even if just vaguely similar) models in the Comsol-supplied Application Library.
Defining the frequency in the frequency domain study does indeed define the frequency. If/when you specify 0.4mA for the input current, that will then set the *amplitude* of the implied *sinusoidal* current (at the subject frequency) to 0.4mA. I'm not entirely sure what you are doing in detail in regard to this or your other boundary conditions, but I think (tentatively) that you are on the right track. You might also want to check if there are some similar (even if just vaguely similar) models in the Comsol-supplied Application Library.
Walter Frei COMSOL Employee
Posted: 7 months ago 2024年2月15日 GMT+1 19:28
Updated: 7 months ago 2024年2月15日 GMT+1 19:32
Hello, See, for example, these resources:
https://www.comsol.com/support/learning-center/article/27591/132
https://www.comsol.com/blogs/understanding-the-excitation-options-for-modeling-electric-currents/
https://www.comsol.com/blogs/modeling-dispersion-in-an-electric-currents-model/
Hello, See, for example, these resources: https://www.comsol.com/support/learning-center/article/27591/132 https://www.comsol.com/blogs/understanding-the-excitation-options-for-modeling-electric-currents/ https://www.comsol.com/blogs/modeling-dispersion-in-an-electric-currents-model/
