Time-dependent problem: noisy temperature boundary condition. Is it possible to change the noise magnitude in a sweep analysis?
Posted 2024年2月26日 GMT+1 15:26Heat Transfer, Modeling Tools & Definitions1 Reply
Hello people,
Is it possible to sum to a triangular temperature profile, defined as a piecewise linear function in the range from zero to 6000 minutes, a random signal (describing a sort of noise) with a variable magnitude that maybe I can change in a sweep analysis? I tried everything but there is no possibility to generate a random signal in exactly the same period of the temperature profile.
What would you suggest to do?
Thanks in advance.
1 Reply
Last Post 2024年2月26日 GMT+1 22:32
