Time-varying single conductor coil excitation
Posted 2024年2月26日 GMT+1 18:01Electromagnetics, Physics InterfacesVersion 6.13 Replies
I am trying to model the magnetic field around a single-conductor induction coil in a 3D-model in COMSOL 6.1. I want to enter a time-varying coil excitation in the Coil node, in my case 50A for the first 90s then 0A for the next 60s, to simulate that the induction is turned off. I am using two study steps: a Coil Geometry Analysis and then a frequency-transient step in which I define the frequency (400kHz in my case). When I put a fixed value of current for the excitation in the Coil node, the model runs well. But when I add the current as a function of time, the model runs until the first step (0.15s) and then never converges. I left it run overnight and it was still blocked there. I tried different function, like 50step(t), 50(t<90), etc., but it always blocks the same way. Even if I reduce the total time (let's say 1s at 50A then 1s at 0A), the model faces the same problem (after step 1 at 0.01s in that case).
Any clue on how to solve this issue?
Thanks!
