Spatial volume integration in partial 3D domain from Derived values?
Posted 2024年3月10日 GMT+1 21:47Interfacing, Modeling Tools & Definitions, Modeling Workflow2 Replies
Hi, guys,
I intend to obtain data using volume integration from Derived Values. The thing is that i only can get the data of whole 3D domain (such as -10mm=
If all you want is to employ simple constraints onx,y, orzduring evaluation, then simple Booleans are very easy to apply. Just multiply your integrand by the appropriate Boolean expression. Atrueexpression evaluates to 1 and afalseexpression evaluates to 0. For example, suppose you want to integrate a quantityfbut only where x<7. Then integrate the quantity f*(x<7). You can combine Boolean expressions to create more complicated logical constraints. Look up the available "operators" in the Help system. Use "&&" for the logicalandoperation and "||" for logicalor. For example, (x>3)&&(x<7) will evaluate to one if x isbetween3 and 7, but will evaluate to zero otherwise.
An alternative is to use one or more Filter datasets. This usually gives a more accurate result than multiplying the integrand by a Boolean expression.
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
