difference of check and uncheck "generate default plots" when solving
Posted 2024年3月14日 GMT+1 02:36Results & Visualization, Studies & Solvers, Structural MechanicsVersion 6.21 Reply
I couldn't figure out what's the difference between check and uncheck "generate default plots". I filmed a video attached to this discussion, in which some details are shown to clarify.
Hi Haiyang,
When theGenerate default plotscheck box is selected, default plots are generated when you first solve the model and are updated when you re-solve. If you change or remove such default plots, you need to right-click theStudynode and chooseReset Default Plotsfirst; otherwise they will not be added or modified to the original default plot settings when re-solving. The plot while solving in your movie is not affected by the default plot settings. It uses the plot group that you select underResults While Solving.
Magnus
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
