how mark a line/point/surface in an animation/figure
How to keep track of and mark a line/point/surface with known x,y,z as red in an animation/figure under results to manifest that line/point/surface?
2 Replies Last Post 2024年3月26日 GMT+1 06:23
Posted: 5 months ago 2024年3月20日 GMT+1 14:01
If you want to trace a point at a certain location, use aPoint Trajectoriesplot.
If you want to track a certain Point/Line/Surface, add a plot of the same type, set the color toUniformRed, and add aSelectioncontaining only the intended object. You can then add aDeformationnode to make it follow the structural displacements.
Henrik Sönnerlind
COMSOL
If you want to trace a point at a certain location, use a *Point Trajectories* plot. If you want to track a certain Point/Line/Surface, add a plot of the same type, set the color to *Uniform* *Red*, and add a *Selection* containing only the intended object. You can then add a *Deformation* node to make it follow the structural displacements.
Posted: 5 months ago 2024年3月26日 GMT+1 06:23
thank you very much Dr Sönnerlind
