"Expression" under "Datasets -> a certain dataset" functions or not?
Posted 2024年4月2日 GMT+2 05:28Results & VisualizationVersion 6.22 Replies
I found that, for the part of "Expression" under "Datasets -> a certain dataset", it's no use to have this part, since no matter plot or export the data, you need to enter the expression again.
Even you plot this dataset, it shows (my guess) just the FEM nodes' distribution, right?
Then my Qs are 1. Does this part do function? What's its function? 2. Plotting the dataset plots simply the FEM distribution, right?
TheIsosurfaceandContourdatasets would typically be used when you use one expression in the dataset and another expression in the features that uses the dataset. An example: Suppose that you want to compute the area of the isosurface c=0. Then you can use anIsosurfacedataset where you specify c=0 and aSurface Integrationfeature that refers to theIsosurfacedataset and uses the expression 1. You can also use aSurface Measurementfeature to compute the area.
To illustrate Gunnar's point, the attached file shows how you can use an Isosurface dataset to create a plot of the magnitude of the heat flux on the complicated surface defined by the fact that the temperature equals 300 kelvin on it.
-------------------Jeff Hiller
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
Suggested Content
- FORUMWhat is the functions of ec.normJ?
- BLOGGetting the Stats: Computing Standard Deviations and Other Statistical Quantities
- KNOWLEDGE BASESolving Wave-Type Problems with Step Changes in the Loads
- BLOGGenerating a Simulation Mesh of a Femur From 3D Data
- FORUMRandom functions that satisfy a certain condition
