Is Changing the end time of simulation, affects the result?
Posted 2024年4月5日 GMT+2 07:371 Reply
Hi all, I am new to the comsol, i am facing the issue of changing the run time of my simulation. for example, I run the simulation for 3.5 seconds, its run smoothly. without changing any parameter, if i change only the end time of my simulation to be 20 seconds, then my simulation shows error. what is the reason for this. And also if i change the end time, what are the factors will affect?
Please help me out from this. Thanks in advance
Hello Silambarasan,
By default, the initial timestep taken by the solver is dependent on the final time. So when you change the final time from 3.5 seconds to 20 seconds, the solver attempts to solve the same problem but starting with a longer initial timestep, and occasionally that longer initial time step may result in the solver performing noticeably differently. That seems to be what's happening with your model. Please refer tothis Knowledge Base entryfor a more detailed explanation and guidelines on how to proceed.
-------------------Jeff Hiller
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
Suggested Content
- FORUMWhy only changing the range of output times affects the results?
- BLOGHear the Sound of an Organ Pipe Design with a Simulation App
- KNOWLEDGE BASEControlling the Time Dependent Solver Timesteps
- KNOWLEDGE BASEHow does COMSOL Multiphysics handle complex-valued numbers and problems in the frequency domain?
- KNOWLEDGE BASEImproving Convergence of Transient Models
