Java Unsuccessful link Error
The below post is related to anarchived discussion
[start here] I am getting the same error as the person before when I tried to run COMSOL API in linux .
My error is:
Exception in thread "main" java.lang.UnsatisfiedLinkError: 'void com.comsol.nativejni.util.FlLicense.initWS0(com.comsol.nativejni.CPointer, java.lang.String, java.lang.String)' at com.comsol.nativejni.util.FlLicense.initWS0(Native Method) at com.comsol.nativejni.util.FlLicense.(SourceFile:71) at com.comsol.nativejni.util.FlLicense.getInstance(SourceFile:81) at com.comsol.nativeutil.e.d.(SourceFile:22) at com.comsol.nativeutil.e.c.l(SourceFile:657) at com.comsol.model.util.ServerModelUtil.create(SourceFile:43) at com.comsol.model.util.ModelUtil.create(SourceFile:92) at RunComsolModel.run(RunComsolModel.java:10) at RunComsolModel.main(RunComsolModel.java:7)
My code is :
import com.comsol.model.*;
import com.comsol.model.util.*;
public class RunComsolModel {
public static void main(String[] args) {
run();
public static Model run() { Model model = ModelUtil.create("Model"); model.modelNode().create("comp1"); model.geom().create("geom1", 3); model.geom("geom1").feature().create("blk1", "Block"); model.geom("geom1").feature("blk1").set("size", new String[]{"0.1", "0.2", "0.5"}); model.geom("geom1").run("fin"); return model; } }
Is there a fix forwhat is going on? I have set the environment variables for LD_LIBRARY_PATH and LD_PRELOAD
0 Replies Last Post 2024年4月5日 GMT+2 15:50
Hello Nikhil Antony
