combination solution at different positions in the same point or line graph
Posted 2024年4月16日 GMT+2 17:513 Replies
Suppose I have a solution written generally as u(x,t). I need to compute u(0,t)-u(1,t) and plot this quantity as a function of t. I've found even for this trivial application in point graph or line graph under a 1D plot, I have difficulty. I need to pick the x=0 point or edge to obtain u(0,t) and pick the x=1 point or edge to obtain u(1,t) but there's no way of putting u(0,t) and u(1,t) together in the same point graph or line graph!
I'm guessing that you may find Comsol's "spatial at" operator to be helpful. The explanation in the Help system may seem a bit overwhelming at first, but be patient. As an example in 3D space, to evaluate your expression expr, at an example (x,y,z) location = (1,0,-1), this would become: comp1.at3(1,0,-1,expr) . Anyway, here's the details, in all their glory, from the Help system: ..... SPATIAL AT The operator evaluates an expression expr in a specific point in space. Typically, use ati without extra arguments when evaluating inside a mesh and add extra arguments when evaluating outside the mesh or even outside the geometry. • The scope.ati(
Dr Koslover thank you very much
However, how to capture an expression in the spatial frame on a moving boundary? e.g. to capture the speed (or another quantity) of the (spatially) right most point on a rolling circle rolling to the right.
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
