Parametric sweep not being made/showing any plots
Posted 2024年5月16日 GMT+2 16:102 Replies
I encounter an issue when I try to perform a parametric sweep for my meshsize. I am trying to get a plot showing how it changes based on what meshsize one gets for each frequency in my plot (mainly the eigenfrequencies). How come my parametric sweep is not being performed or it is being performed but only showing one constant value? I will attach a picture of my sweep as well as my model file.
Thank you in advance!
Merna,
You are plotting the mesh size parameter over frequency, which is of course a constant over the frequency sweep. I guess you rather want to plot some physical result quantity as a function of frequency for the range of parameter values. Each parameter value will then show the respective frequency response for this quantity.
Cheers
Edgar
emPhys Physical Technology
www.emphys.com
Thank you very much for your response Edgar.
All the best!
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
Suggested Content
- BLOGVideo Tutorial: Introduction to Modeling Structural Mechanics
- KNOWLEDGE BASEPerforming a Mesh Refinement Study
- KNOWLEDGE BASETroubleshooting Graphics Issues
- KNOWLEDGE BASERunning parametric sweeps, batch sweeps, and cluster sweeps from the command line
- FORUMHow to export all plots and all plot data for every experiment in a Parametric Sweep?
