How to extract fluid domain from the given solid domain
If I have a complicated geometry, and i want to do the fluid flow analysis inside that geometry, how will I cretae a fluid domain from the given solid geometry?
3 Replies Last Post 2024年6月6日 GMT+2 14:22
Posted: 3 months ago 2024年6月5日 GMT+2 14:46
Hello Lakshmi sree,
You can use the "Cap Faces' capability. Seethis old post, for instance, for more detail.
Hello Lakshmi sree, You can use the "Cap Faces' capability. See [this old post](https://www.comsol.com/forum/thread/241541/create-cfd-mesh-from-cad-geometry?last=2019-08-27T17:39:06Z), for instance, for more detail. Best regards, Jeff
Posted: 3 months ago 2024年6月6日 GMT+2 07:26
hello Jeff Hiller, Thank you for the support. Once I create the fluid geometry from the structural geometry, how do i delete the structural geometry, Because I want to work only with fluid geometry
Thanks and regards Lakshmi sree P
hello Jeff Hiller, Thank you for the support. Once I create the fluid geometry from the structural geometry, how do i delete the structural geometry, Because I want to work only with fluid geometry Thanks and regards Lakshmi sree P
Posted: 3 months ago 2024年6月6日 GMT+2 14:22
You should be able to delete it like you would delete any other geometry entity, nothing special.
You should be able to delete it like you would delete any other geometry entity, nothing special. Jeff
