Phase Change material based heat exchanger video
Posted 2024年6月19日 GMT+2 16:534 Replies
Dear Sir
I am working on the area of PCM. Can you share any video regarding PCM based heat exchanger?
What aspect of model set-up specifically are you struggling with?
-------------------Jeff Hiller
Any kind of heat exchanger filled with phase change material that one is cool or heat by flow of water/fluid flow.
I meant: geometry creation? meshing? physics set-up? solver settings? postprocessing? etc. Because COMSOL software is used to simulate an extremely broad range of systems, you can imagine that the odds that a user of this Discussion Forum has a ready-made video detailing every aspect of setting up a model of your specific system are very low.
If you are just starting with the software, there are quite a number of resources you can draw upon to learn how to use COMSOL Multiphysics regardless of your specific application. I am mentioning here the main ones, in no specific order, and I should mention that this is not a complete list by any means. I hope it will prove useful to you nonetheless.
First, of course, there is the software's documentation. You can access it through the File > Help > Documentation menu or by browsing your COMSOL installation folder to the "doc" folder. The documentation includes both theory manuals and tutorial manuals. Many tutorial models are also available already set up inside the software via File > Application Libraries.
The COMSOL website also offers many video tutorials on a wide range of topics in theVideo Galleryand worked-out models in theApplication Gallery. You will also find longer archived webinarshere. The COMSOL website also offer aBlog, in which many posts discuss how to simulate specific phenomena or using particular features of the software; they are highly technical and detailed.
COMSOL offers manyinstructor-led training courses.
Finally, and maybe most importantly, I strongly recommend theLearning Centervideos to get a solid foundation for your modeling with COMSOL: they cover the entire process of setting up a model from start to finish, and are a great resource for self training.
I have seen the library, under that can you provide packed bed latent heat storage video which one will be useful for me?
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
Suggested Content
- BLOGHow to Model a Shell and Tube Heat Exchanger
- FORUMChange Material Properties based on First Solution
- KNOWLEDGE BASEHow can I see the equations COMSOL is defining?
How do I implement a user-defined Multiphysics coupling? - FORUMPhase Change Material
- BLOGApp: Studying a Concentric Tube Heat Exchanger's Dimensions
