4.2a Acoustic Streaming
Posted 2024年6月25日 GMT+2 15:33Acoustics & Vibrations, Computational Fluid Dynamics (CFD), Microfluidics3 Replies
I am trying to create a simulation of the acoustic streaming in COMSOL v4.2a. As this is quite an old version, I cannot find much information on the subject.
I understand that first-order fields should be solved with a pressure acoustics or thermoacoustics interface, and then these fields should be implemented as source terms(?) in a laminar flow interface.
Actually carrying out this process seems complex.
Is anyone able to advise me on where I can find more detailed instructions on modelling the acoustic streaming in v4.2a, or would anyone have any model files that they would be willing to share with me.
With best regards, Peter
Peter,
just for your information, the current version 6.2 has it readily available with a time explicit solver. I have been doing some extensive work with it, with good success. I would not want to go through the exercise to cook it by myself in an old version.
Cheers Edgar
emPhys Physical Technology
www.emphys.com
Peter,
Cheers Edgar
Dear Edgar,
Thank you for your reply. I have seen the available multiphysics for acoustic streaming but unfortunately I do not have access to the latest version. I have been attempting to recreate results from literature on the subject that used the 4.2 version but their explanations of the details are vague.
I understand this is not ideal but it is currently my only option.
Best regards, Peter
Just as a follow up, I tried to followthis paperwhich seems to state that I need to add a body force and a weak contribution to the creeping flow interface in terms of the first-order field variables solved for in the acoustics physics interface.
I don't have any experience with equation-based modelling but if anyone could assist me in how I can add these contributions to the fluid flow interface it would be a great help.
The authors say they added aweak contributionwhich I think is implemented aswhich corresponds to the RHS ofthis equation. But I am not sure how to implement the RHS ofthis equationas a volume force.
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
Suggested Content
- FORUMAcoustic-Solid Interaction Coupling
- BLOGAnalyzing Forced Duffing Oscillations in Metal-Halide Lamps
- BLOGAcoustofluidic Multiphysics Problem: Microparticle Acoustophoresis
- FORUMAcoustic streaming from a vibrating needle in a droplet
- BLOGModeling an Acoustic Trap: Thermoacoustic Streaming and Particle Tracing
