Inability to Add Boundary Conditions to Interior Boundaries
I have been struggling with how to apply interior boundary conditions to my model for the past several weeks. I went back to basics and drew an incredibly simplified model and added only one Physics node (Laminar Flow) to see if perhaps I had made a mistake while building my other model.
However, I am experiencing the same issue with this model.
I have read all the other discussion posts, and have tried using the assembly, makiing sure 'keep interior boundaries' is selected as well as using other Booleans and Partitions but no matter the settings I use, I am unable to select the interior boundary as it reads 'Inapplicable.' I suspect the Legacy Wall Feature might be to blame, but find I am still unable to select any interior boundaries as a Wall.
Any advice would be sincerely appreciated and thank you so much in advance.
2 Replies Last Post 2024年7月25日 GMT+2 22:21
Posted: 1 month ago 2024年7月25日 GMT+2 22:12
Hello Sarah,
You would need to use the "Interior Wall" feature instead of "Wall". Whether the license you are using includes that feature depends on which add-on modules were purchased for that license. See theSpecification Chartfor more details. You can find out which modules are on your license under File > Licensed and Used Products.
Hello Sarah, You would need to use the "Interior Wall" feature instead of "Wall". Whether the license you are using includes that feature depends on which add-on modules were purchased for that license. See the [Specification Chart](https://www.comsol.com/products/specifications/) for more details. You can find out which modules are on your license under File > Licensed and Used Products. Best regards, Jeff
Dave Greve Certified Consultant
Posted: 1 month ago 2024年7月25日 GMT+2 22:21
A workaround would be to give the interior wall some thickness and exclude it from the simulation domain (so you don't have to mesh a thin region).
