different parametric solution
Posted 2024年8月7日 GMT+2 08:400 Replies
Hey dudes, I have a technical question. I am working on COMSOL, electromagnetic waves module, frequency domain to see the plasmonic resonance of nanohole array. but I have two problems. one is that after simulation I have many different "parametric solutions" and I don't know which one is the main output response. what is the use of these parametric solutions? the second is, when I decrease the step of lambda to change the wavelength as parametric sweep, the output changes. how can solve this problem? meanwhile, I changed the meshing but I didn't get result. thanks
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
Suggested Content
- FORUMinitial solution taken by last step in parametric sweep or auxiliary sweep
- FORUMcombination solution at different positions in the same point or line graph
- BLOGThe Power of the Batch Sweep
- KNOWLEDGE BASEError: Failed to Connect to PTC Creo Parametric
- BLOGSolution Joining for Parametric, Eigenfrequency, and Time-Dependent Problems
