how to define P-polarized and S-polarized light for 3D geometry in COMSOL 6.1
Posted 2024年8月14日 GMT+2 11:23Wave Optics, GeometryVersion 6.12 Replies
Dear fellows, I hope you are doing well.
Could you please guide how to define components for S-Wave and P-wave of Electric field incident at specific incident angle on 3D geometry in COMSOL 6.1.
It would be appreciated if some tutorial or example can be provided.
Thanks in anticipation.
S-and p-waves are a concept of seismic waves. They do not exist in electromagnetic waves.
Edit: Just saw, that the concept is used for light reflection and transmission on a surface. That is basic geometry. The s-component is parallel to the reflector surface and perpendicular to the propagation direction. The p-component is perpendicular to propagation direction and s-component. You can define a respective coordinate system in COMSOL.
emPhys Physical Technology
www.emphys.com
Dear Edgar J. Kaiser,
Thank you for the reply and suggestion. I am using the following components of input Electric field for P-wave E(cos (incident angle), 0, sin(incident angle)) in COMSOL 6.1 but results are with very high intensity but this is not the case in experiment. I have also tried with E(1,0,1) for P-wave reflection, result is again the same. While for same model with Electric Field components for S-Wave E(0,1,0) works well. Please suggest any solution for P-waves Reflection. Thanks in anticipation.
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
Suggested Content
- FORUMHow to calculate the co and cross polarized transmittance/reflectance in Comsol?
- BLOGStudying the Polarization of Light with a Fresnel Rhomb Simulation
- KNOWLEDGE BASESetup and Meshing of Infinite Elements, Perfectly Matched Layers, and Absorbing Layers
- FORUMHow to Create a Linearly Polarized Electromagnetic Wave (Light) Source.
- KNOWLEDGE BASEHow can I see the equations COMSOL is defining?
How do I implement a user-defined Multiphysics coupling?
