Adding a mass on a hollow tapered cylinder
Posted 2024年8月22日 GMT+2 12:10Mesh, Modeling WorkflowVersion 6.22 Replies
Hi, i m trying to add a mass to the top of a tapered hollow cylinder in beams but it's not working. i have tried add point mass but it's not working or it adds the mass at the edge but i need the entire top surface of the cylinder at the center of the top cylinder. Also the top surface should not squeeze in any direction because it only represents in the mass of nacelle-rotor component in a wind turbine model. should i use in this case rigid connector?
thanks Filippo
I think you need to attach a sketch or a model file to make it easier for anyone to give suggestions.
-------------------Henrik Sönnerlind
COMSOL
Sorry, I thought I attached it .
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
Suggested Content
- FORUM3D cylinder with spheres
- KNOWLEDGE BASEDesign Module License Checked out Directly when Starting 2D Drawings
- KNOWLEDGE BASELicensed Number of Users Already Reached on a Linux machine with a CPU/NSL license
- BLOGUsing Geometry Parts and Part Libraries in COMSOL Multiphysics®
- FORUMTapered Waveguide
