Limiting variables in Monolithic solver
Posted 2024年8月28日 GMT+2 00:57Studies & Solvers, Structural Mechanics, Material Models4 Replies
Hello COMSOL Community,
In the typical segregated approach, it’s possible to limit a variable between an upper and lower bound. In the case of, the phase field variable needs to remain between 0 and 1. However, when using the monolithic or fully coupled solver, I haven’t found a way to enforce these limits.
My question is: How can I ensure that the phase field variable stays within the range of 0 to 1 when calculating energy, which depends on this variable, while using the monolithic solver?
I would appreciate any insights or suggestions on how to approach this issue.
Thank you!
Hi Aida,
If possible, it is usually better to enforce the limit on the phase field from the governing equations instead of setting a limit in the solver, since the latter will disregard the equations where your bound is violated. This means that you can get an arbitrarily large residual.
In version 6.2, with the Phase Field in Solids interface, you can use the Bounds subnode to a Phase Field Model node to specify these kind of inequality constraints.
If you are working with a phase field damage model like AT1, which is unbounded, an alternative approach to adding inequality constraints is to analytically derive the minimum energy that is necessary for a zero solution and add this as an additional source term in the phase field equation.
Adam Wahlsten
COMSOL
Thank you for your response, Mr Adam
However, I've noticed that the "Weak Contribution" sub-node doesn't exist under the " Phase Field in Solids" node. How can I resolve this issue?
Hi Aida,
Could it be that you have not yet activated theEquation-Based Contributionscheckbox in theShow More Optionswindow (which you open from the top of theModel Builderwindow). Then you should be able to addWeak Contributionsubnodes.
Magnus
Hi Magnus,
Thank you for the suggestion! I tried to add the Weak Contribution subnodes as needed, and it worked perfectly. Thanks again for your help!
Best regards, Aida
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
Suggested Content
- BLOGModeling Surface Reactions in Porous Media and Reactive Pellet Beds
- FORUMPlotting variables which are not defined as dependent variables but are used in the physics equation
- KNOWLEDGE BASESegregated solver steps do not involve all components
- KNOWLEDGE BASEBDF, Generalized Alpha, and Runge-Kutta Methods
- BLOGFluid-Structure Interaction (FSI) using COMSOL Multiphysics
