Making a line graph from streamline
i have a project about a cutting fluid in laminar flow, and i highlighted the flow using streamlines. i have solved the fluid behavior in x-component as well as its magnitude . i also have designed the graph using the 3-D cut lines and plot it in 1-D. Now, the problem is that the velocity magnitude from the simulated graph is neither the same nor correct as the velocity magnitude from the streamlines information
Can you please help me fix the problem???
