Solver error only at lower frequencies
I am looking at a magnetic fields study in which I want to produce some eddy currents in a copper plate above an alternating magnetic dipole.
I have attached the .mph file
When I run a frequency domain study at 10,000 Hz everything seems to solve fine. When I reduce the frequency to say 100 Hz or 1000 Hz and press the Compute button, I get the following error:
  • Feature Stationary Solver 1 (sol1/s1) Failed to find a solution. Matrix has zero on diagonal. Returned solution is not converged. Bot all parameter steps returned.
Can anyone see what the cause is? Thankyou in advance for any input.
1 Reply Last Post 2024年10月1日 GMT+2 17:40
Posted: 1 day ago 2024年10月1日 GMT+2 17:40
Jamie,
you need a small electrical conductivity in the air domain (e.g. 1 S/m) for numerical stability.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Jamie, you need a small electrical conductivity in the air domain (e.g. 1 S/m) for numerical stability. Cheers Edgar
