EM waves signals
Posted 2024年11月7日 GMT+1 21:39 Electromagnetics, RF & Microwave Engineering 10 Replies
Hello there,
I have an empty steel square box, 50 cm * 50 cm * 50 cm in size, the thickness of the steel plate 2mm. I want to introduce an EM wave source inside the box, like a Gaussian pulse in the order of ns, to observe the attenuation or reflections of EM waves inside and outside the box as time goes on. Besides, there are some holes on the surfaces of the box, and as such, the EM waves should go out through the holes and spread over the outer surface of the box and surroundings. My question is, how can I define the boundary condition in my case study, with an EM source and a box? In transient, there is only the PEC boundary condition.
I very rarely used the temw mode so I had forgotten there was no selection for an imperfect conductor.
You will be able to obtain some insight using the perfect conductor boundary condition. However you should consider doing a frequency-dependent calculation which contains complementary information. In principle it would be possible to use those results to perform an inverse Fourier transform to get the time response.
Actually, I need to see the transient behavior of EM waves over time to see how they propagate. A frequency-dependent solution might not be suitable for my case study.
David suggests to perform a sufficiently broad and fine frequency scan and do a an inverse Fourier transform to obtain the time dependency. You will need to make yourself familiar with Fourier transform theory. The window function which is the Fourier transform of the time dependent excitation is key. It works, I have done it in acoustics models. But it is not exactly plug and play.
Cheers Edgar
emPhys Physical Technology
www.emphys.com
In principle, you can also model the walls (to perhaps a couple of skin depths?) as fully meshed domains within a time domain model, since the temw formalism will allow you to specify a finite conductivity of a domain. This may or may not be practical computationally in your model. If you do take this approach, be sure to define the mesh of the lossy wall volumes carefully, so as to properly model the field gradients in the vicinity of the skin depth, yet not run out of memory. This will be easier if you can do a 2D model instead, or make any other use of symmetry.
Is there any example or article about this principle? Actually, I a little bit confused about your explanations.
See the example attached. This example is not optimized for any purpose in particular. A single cycle of RF is launched by a post inside a square cavity, and then it bounces around in the cavity. There is one lossy domain (note that sigma = 1.0 S/m in the rectangle on the right-hand side). This is only a 2D model. I included a probe to show how the energy in the cavity varies with time (see the Results section, to plot that). All that said, I encourage you to follow the suggestions made by David Greve and Edgar Kaiser above, if you can! They know what they are talking about.
Very nice example Robert!
Cheers Edgar
www.emphys.com
The finite-conductivity approach suggested by Robert will probably be most accurate for a limited range of frequencies, where the skin depth is of the order of the mesh size. So if the exciting waveform is nearly a delta function (with a wide spread in the frequency domain) this would not be the best approach. On the other hand a windowed sinusoid would work very well with the finite-conductivity wall.
If OP chooses to mesh the wall it will be necessary to be very judicious with the approach used. Probably a swept mesh is the way to go.
If the holes are large enough (so that propagation outside is dominant) it may not even be necessary to model dissipation within the box.
Thanks Robert. Actually I defined four walls made of copper (not lossy) and put a air gap on the surface. EM wave should be spreads out from this gap but it doesn't work. I attached the file. I appreciate it if you take a look of it.
The gap is leaking radiation, it is just not very well visible in the linear plot. I often plot log10(normE) to visualize fields over a large range.
I made a little animation that shows the effect.
www.emphys.com
Basic Rules
- Flaming: Do not post any messages that harass, insult, belittle, threaten, or flame another member or guest. Debates are fine, but argue with the point, not the person.
- Trolling: Do not post with the purpose of starting a dispute. Note that a person disagreeing with your opinion is not considered trolling; keep it civil, even if you are sure that the other person is wrong. Anything seen as trolling will result in you being banned.
- Spamming: Posts without content or containing nonsense waste space and everyone's time. Spam will be removed from the forum.
- Offensive Posts, Links or Images: Do not use profanity, racial, ethnic, religious, or other slurs or any other offensive material.
- Advertising: Posting of advertisements for products or services, links to auctions, affiliate links, links to promote websites, and so forth is not allowed.
- Disclosure of Personal Information: Do not disclose any other member's email, real name, address, phone number, IP address, or other personal information. This includes posting contents of emails and private messages without the sender's consent. Do not bring personal disputes into the forums. Bans and warnings issued to other users are considered personal information.
- Misleading Titles: The subject line of the post should be as informative as possible about the content of the post. This also reduces the amount of duplicate posts.
- Thread Hijacking: Taking a thread off-topic to pursue one's own agenda is not permitted.
- Piracy: Do not upload, post, email, transmit, or otherwise make available any content that infringes upon any patent, trademark, trade secret, copyright, or other proprietary rights ("Rights") of any party. This includes COMSOL model files created by a forged or illegitimate license.
- Honesty: Users must provide truthful information in creating their COMSOL Access account.
Posting Guidelines
- Write in English.
Disclaimer
